stickdog
Oct 11, 2016Explorer
All we use is water. Plenty of water is a black tanks friend and yours as well to prevent odors and ensure solid materials, you know what I mean, are flushed when you dump.
If you don't have black tank flush for your tank or don't have acess to a water tap as at most dump stations, but do have a nonpotable source as at most dump stations and are not holding up others, I will fill a couple 5 gal buckets to dump through the toilet to flush any remaining solid deposits. I then close the valve, fill another 5 gal bucket and dump that down the comode to prime the black tank.
No sanitizers or chemicals are needed.
Lets face it you don't pour chemicals down your home toliet unless you have a septic system and then maybe a emzyme digester, though even those are not needed.
As for cleaning the toilet bowl, which is not an area of my expertise, DW uses the same as in the home toilet.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
