bigred1cav
Sep 14, 2017Explorer
IOWA
Any peace officer having reason to believe that the weight of a vehicle and load is unlawful is authorized to require the driver to stop and submit to a weighing of the same by means of either portable or stationary scales and may require the vehicle to be driven to the nearest public scales. If the officer determines that the weight is unlawful, the officer may require the driver to stop the vehicle in a suitable place until such portion of the load is removed as may be necessary to reduce the GVW to the permitted limit.
All vehicles weighing over 10,000 lbs. must stop.
ILLINOIS
A police officer may pull over any vehicle suspected of exceeding weight limits.
LOUISIANA
The following vehicles must stop: (1) agricultural vehicles; (2) passenger or specialty vehicles, either single or in combination (towing a trailer) with GVWR of 10,000 lbs. or more; (3) commercial trucks with GVWR of 10,000 lbs. or more.
MASSACHUSETTS
MINNESOTA
All vehicles with a GVW rating in excess of 10,000 lbs. must stop.
NEVADA
The following vehicles must stop: (1) agricultural; (2) passenger or specialty vehicles either in combination (towing a trailer) with GVWR of 10,000 lbs. or more; and, (3) commercial trucks with a GVWR of 10,000 lbs. or more.
NEW HAMPSHIRE
The driver of every motor vehicle shall, upon request of any law enforcement officer, stop and submit such to a weighing of said motor vehicle by means of either portable or stationary scales. If such scales are not available at the place where the stopping occurs, upon request of a law enforcement officer, the driver shall drive said motor vehicle to the nearest public scales provided the distance to the public scales does not exceed 10 miles.
OKLAHOMA
Any officer of DPS, the Oklahoma Tax Commission, or any sheriff is authorized to stop any vehicle in order to weigh the vehicle with portable or stationary scales.
PENNSYLVANIA
Regardless of size, the following vehicles are subject to inspection and weigh station examinations: (1) agriculture vehicles when using public highways; (2) passenger and specialty vehicles towing large trailers; (3) large recreational vehicles, and (4) trucks.
ILLINOIS
LOUISIANA
MASSACHUSETTS
MINNESOTA
NEVADA
NEW HAMPSHIRE
OKLAHOMA
PENNSYLVANIA
About RV Newbies
