SarahElizabeth's avatar
Sep 05, 2015
Do we need to winterize for a few days in Yellowstone?
Hi there! We're planning on heading to Yellowstone in a few days - but we just saw that the lows are going to be in the 30s. Are we going to have to winterize in order to go? Or will it not be too much of a problem because the temps will be in the 60s during the day?
Thanks so much!
  • Nothing will freeze until the temp gets below 32 and stays there for several hours.
    Even then, nothing will likely be damaged IF no pressure builds up.
    I think if you heat the cabin, turn off the water pump and leave the faucets open you should be fine. Leaving the hot water heater on if you can would be good too.
