Grit_dog
Jun 15, 2016Navigator III
Just secure the wires so they cannot chafe and alternatively, since rubber grommets don't typically work on thicker material like plywood, can either slide on or split and wrap some rubber hose or plastic wire loom around the cables at the points where it will rub and zip tie it tight.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
