Jonnygsx
Dec 06, 2013Explorer
pianotuna wrote:
Hi,
Coat the roof with Herculiner.
Then install the new battery bank at the rear bumper on a rack welded to the frame. Run #6 wire to the OEM connection or to the power center which ever is easier.
I assume you are messing with me now. Herculiner the black truck bed coating does not seem like a good plan.
Wow really? I read a few threads about how it was a very bad idea to install batteries on the rear bumper. I had had that thought too, but most of the threads said that is one of the bounciest spots on the trailer and would damage the batts over time. Also if you were to back into anything or to be rear ended in a wreck battery acid could be all over.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
