PapPappy
Aug 08, 2013Explorer
Usually, metal is metal all the way.
If you can move it at all, it's probably rubber, not metal. (Check your car wheels, and see if you can move the piece a bit?)
When you put in the tire minder, you'll find out for sure, so just have some extra money, if you need to change to the metal.
Also a good time to have extensions added, to make checking/adding air pressure a bit easier too:)
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
