LarryJM
Aug 09, 2013Explorer II
Vanhollymorgan wrote:
On the road warrior i bought, the rims are 110psi, gonna buy a tire minder system, but how do i know for sure ive got metal valve stems. Mine have a little bit of rubber at the base, but about 1/2 inch of metal after that. Will a rubber one be rubber to the tip?
IIRC tireminder says you really don't need metal valve stems with their newer non flow thru sensors, but I agree they are probably the best. I have shorter "fat" rubber stems on my new AL rims with the SS valve stem cover on them and just got the TM system and will use it on these stems until my next tire change at which time I will change to metal. However, I don't expect problems with what I have now, but time will tell and at least I will know quickly if I do have problems and I will deal with them at that time.
Larry
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
