ependydad
Jul 15, 2013Explorer
Minor edits for my camper:
And, the flush isn't for my sewer hose - it's to get the extra crud and carp out of the black tank. With a clear elbow on each of my sewer connections, I can tell you that it takes 3 actually dumps of my black tank for it to be really clean in there. Otherwise, TP and caca get left behind (even when emptying a fully tank).
scottz wrote:
Hole****** folks! (pun intended) No need to flush anything as long as you have 12 gallons or more in the gray tank! It is always good practice to dump with mostly filled tanks anyways.
1. Connect drain hose
2. Pull Black Lever (wait until it stops)
3. Push Black lever
4. Pull Gray Lever (wait until it stops)
5. Push Gray lever
6. Pull Gray 2 Lever (wait until it stops)
7. Push Gray 2 Lever
8. Move drain hose to second sewer outlet
9. Pull Black 2 Lever (wait until it stops)
10. Push Black 2 lever
11. Pull Gray 3 Lever (wait until it stops)
12. Push Gray 3 Lever
13. Disconnect drain hose and put away.
Drive away
Takes ?? minutes.
About RV Newbies
