Bo-man
Jul 21, 2013Explorer
Pangaea Ron wrote:scottz wrote:
Hole******folks! (pun intended) No need to flush anything as long as you have 12 gallons or more in the gray tank! It is always good practice to dump with mostly filled tanks anyways.
1. Connect drain hose
2. Pull Black Lever (wait until it stops)
3. Push Black lever
4. Pull Gray Lever (wait until it stops)
5. Push Gray lever
6. Disconnect drain hose and put away.
Drive away
Takes 5 minutes.
I do an additional step:
1.1 Open gray handle for a test drain (~1 quart) to see if all the connections are tight and not leaking. Better gray than black.
1.2 Close gray handle.
About RV Newbies
