When it cools in the tlr the comp shuts down but the fan keeps running. Is the fan recirculating inside air or bringing humid outside air? Can the AC be rewired so the fan shuts down when the comp shu...
Your Duo Therm is the basic A/C unit. You can select Cool (low, med, high).....in 'cool' mode fan runs continuously and compressor cycles ON/OFF dependent on t-stat knob setting (coolest setting 65*F to warmest setting 90*F) You can select Fan (high, med, low).....just fan runs.
So whenever unit is turned ON..fan is going to run It circulates inside air only....no outside air.
