When it cools in the tlr the comp shuts down but the fan keeps running. Is the fan recirculating inside air or bringing humid outside air? Can the AC be rewired so the fan shuts down when the comp shu...
If you are very determined to get the fan to shut off while you are in bed you could put a timer in the power source to the AC unit with a switch to bypass it during the day. If you shut the fan off the same time as the compressor the temp sensor will not get warm air going past it to tell the compressor when to come back on.
