RoyB wrote:
What weight is listed on the Title you have for this trailer. That is what the Law Enforcement is going to go by when the trailer license is run through their system check.
What is the model of the trailer.
What will happen is Law Enforcement will possibly look over your way when passing you and your trailer and see the trailer breakaway cable not hooked up and it will go down hill from there for you... If all of this is mounted on the trailer tongue I would most definitely have it all hooked up working or not...
If your trailer becomes disconnected on public roads and causes alot of damage or worse then your Insurance may NOT go in your favor if everything is not up to legal status.
You know how all of that goes haha...
Our State also requires a State Inspection Sticker for trailers that weigh a certain weight and have Brakes installed. If we have an expired Safety Inspection Sticker we can usually be allowed to pull the trailer to a Inspection Station if we call ahead and let the garage know we are in-route.
Even my small utility trailer I have here has a valid State License tag on it... Its title says EW is 700lbs and GW is 2990lbs. All it requires is working safety lights
Roy Ken
X2, I have exactly the same trailer.
