sleepygeek wrote:
Would a Heavy chain dragging from hitch be any help to disperce the lightning charge, the walls and floor have a 2 inch square tubular ridged frame spaced about 4 feet apart ( vertical+ horizontal ) as in a cage, connected to the truck frame. Would this not be of any help against lightning.
I'm not an expert on this. Everything I've ever read on this subject says that it's the metal SKIN of the vehicle that carries the electricity AROUND you and into the ground, right through the rubber tires. absent that metal skin, I would guess the lightning could pass right through you and then get carried into the ground via this heavy chain. Which would kill you.
Vehicles and Lightninghttps://www.weather.gov/safety/lightning-cars
