ericsmith32's avatar
ericsmith32
Filling a hidden fresh water tank
On the past RV's I've filled there's a separate tank filler and city water hookups. On our current Jayco it's all in one just change a few valves and open one of the faucets. The problem is when is it full? The tank is above the axle with no visible indicator anywhere except the control center. With the filler like the gas tank it was fairly easy!
I've only had to fill it three times so still trying to figure it out. The 2nd time I got busy and forgot to open the faucet well it pressurized and I'm guessing there's a pressure release since it shot out all the excess water and air which left 2/3 of tank, the manual says nothing of course. This last time I got it to indicate full but I'm sure it's not completely full. I don't want to split the tank. Anyone else with a hidden tank and how do you handle it?
Eventually I'd like to relocate the tank to tanks but that's another story and project!
  • Mine has overflow. Has to have some way to get air out as water goes in. My manual just says don't leave it on walk away. You may just want to call Jayco.
  • I think all those fillers are the same. I 've been turning valve to tank & watching it inside the MH. When tank monitor says full I go out and turn it back over to city water. I suspect they have an over flow. I'm going to check my manual again.
  • Not certain on your unit, but most I've seen/had have an overflow on the fresh water tank that dumps any excess.
    Someone with a similar unit will no doubt confirm or correct.
    Bill
