Kostyan's avatar
Kostyan
Finding replacement for Fairview GR-9984 LP gas regulator
Hi guys
Trying to tackle this one myself and discovered that any available Fairview GR-9984s on the internet look different than the one installed on my camper.
I googled for older model Fairview GR-9984 and found one reference to my unit which is here: https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24574749/print/true.cfm
Any ideas on how can I find a replacement?
  • Kostyan wrote:
    SoundGuy wrote:
    Why does it matter? ... any auto changeover regulator will work just fine, including the current GR-9984.
    Possible difficulty mounting using existing bracket but also not knowing interchangeability of these things.
    Bracket should be the same. If not, Amazon sells them.
    Clicky
    If the regulator died, the pigtails are probably not far behind. I would replace them too.
  • "Why does it matter? ... any auto changeover regulator will work just fine, including the current GR-9984."
    Hmm, good point. :h
