valhalla360
Apr 14, 2021Navigator
th3_fix3r wrote:
I only have one sticker on the door jam. it says combined weight of occupants and cargo should never exceed 1180lbs. Then it has tire pressure stuff. Says see owners manual for additional info. The owners manual just says exactly what i posted in original post. I'll check out that site.
Ewww...that's even worse. You basically have pretty much the worst options in a 1/2 ton for towing. I take it back that the salesman was being slightly conservative. He's dead on correct that 4000lb (fully loaded trailer) is probably about the most you could do and stay within spec on the truck.
About RV Newbies
