valhalla360
Apr 14, 2021Navigator
th3_fix3r wrote:
Update. I just called the Dodge dealership. Told them what I had and he looked it up by my VIN. He says my towing capacity is 9850. It has a "392 rear end?" and he said the GCWR?? is 15,500. Tongue weight should be 10-15% towing capacity so as long as i stay around 1400 or preferably below on tongue weight I'm solid. I'm confused about what you said anyway @Valhalla360 because the manual says towing from 5000 to 9850. I don't know where you got 5000 being max. Maybe you thought (and it says) 5000lbs could be the limit but thankfully apparently mine has the highest possible limit of the different versions of my truck. Sound right? Idk. SO new to this. I know it pulls my pontoon boat quite well. HAHA
Sorry, your first post wasn't clear. There isn't typically a minimum tow rating, so I thought the 5000lb was the tow limit you found.
But regardless, you run into payload limits before you would ever get close to the 9850 tow rating.
If the payload is 1180lb, 1400 tongue weight would already be over by 320lb without you even in the truck.
About RV Newbies
