Grit_dog
Apr 17, 2021Trailblazer
toedtoes wrote:JimK-NY wrote:bikendan wrote:
Those that say "just do it" are almost always experienced towers and aren't taking in the fact that the vast majority of the "can i tow this" group, have never towed anything. ...
I doubt previous towing experience will be of much help if any overloaded tire blows while driving at high speed on an Interstate.
Someone with years of experience in towing will be more likely to understand how to react when that tire blows. A towing newbie in that situation is very scary.
Yet here 3 of you are talking about tires blowing out, presumably with no knowledge that even the lowest rated tires you could likely drive off the new car lot with on a well equipped half ton pickup would easily handle 2500+ lbs of rear axle payload before reaching their rating.
And being a 2012, maybe the appropriate question is “Wwhat tires you running?” , not blathering about a component that is easily figured out as not being the weak part of the gvws equation. It’s not even the weak part of the rawr equation.
About RV Newbies
