Kavoom
Apr 22, 2021Explorer
th3_fix3r wrote:
I'm screwed, huh? So although I can technically pull almost 10Klbs... the tongue weight alone screws me?
Not really... Three people? I have a 2015 Ram Outdoorsman with similar ratings although a couple hundred lbs more capacity, but do the math? We got an Aspen Trail 2340 at 5500 dry weight and 600 dry hitch weight add 200 lbs for batts and propane. So, we are at 800 there. Us and the dogs are let's say 250 lbs (All right 300). so you are now at 1050. Put a WDH (hitch) and you are there. I think you can feel safe putting a cooler in the back. So, you have to adjust around NOT really using your truck bed for much but that's not all that different than people with SUV's so... I can put a couple of things more as I have a couple more lbs but that will teach you to get a laramie. All those goodies that come on em add up weightwise. My understanding is that the "capacity" for the RAM linked site is calculated with a full tank of gas also. If you have the big gas tank (32 gal) that is 265 lbs... So, be cognizant of capacity, but don't count ounces... You will run through that gas real fast like 9 MPG... I also have 2K capacity for the trailer to stow stuff and a 7700 lb total. So, that is where your trailer towing capability on the RAM is good to go.
I also put air bags on it and have a Fastway E2 Hitch (10K version). The airbags do NOT necessarily ADD capacity but they don't hurt and improve the ride while the WDH will shift weight to the front keeping you level AND helping the overall situation.
Oh wait, if you are looking for an excuse to get a 2500, then never mind
About RV Newbies
