Grit_dog
Apr 22, 2021Trailblazer
JimK-NY wrote:th3_fix3r wrote:
Well... this has been fun. Loads of fun. I'm buying a diesel. 25-3500 Ram. Maybe i'll meet some good folks when i get out there so i don't have to ask my newbie questions here and sort through 7 pages of contradicting arguments. To those of you who have truly just tried and successfully provided information and not been jerks: thank you a ton for your input!
If you look at the Ram 2500, be aware that it has coil springs in the rear. That will give a cushy ride but limit any attempt to beef up the suspension if you ever need to use the truck at full load capacity. I am sure opinions will vary on this with contradicting arguments, but I would never buy one.
I agree with this if considering a larger truck camper. And have similar sentiments.
However after driving and towing with a bunch of 4th Gen 2500s and now being the owner of one, they perform the same as any other 2500. And aren’t that limited in suspension upgrades.
Options are, in order of ease of install:
Timbrens or sumos
Airbags
Aftermarket springs.
Realistically, if I was hauling heavy I’d just pop for a new set of springs. Coils are pretty easy to swap out and actually cheaper than airbags.
Been hauling a tongue heavy 7klb snomachine trailer with ours this winter. And an (estimated) 1000lb tongue weight would not quite level the truck out
Mine is lifted, leveled 6”F/4”R lift with OEM rear springs on spacers so the tongue weight puts the truck nose high. I just bought bags to compensate for that because will be towing a heavy tongue weight camper this summer. Well over 1000lb guessing.
But the truck with a cheapo 6” lift and 37s tows a 34’ long enclosed trailer like it figuratively “isn’t there.”
Point is the Ram coils don’t s uck. Given the option I’d get leafs only because I’m really a TC guy and they’re not suited well for that application.
About RV Newbies
