wa8yxm
Nov 29, 2014Explorer III
Consider this next time,, There are two ways to winterize, Wed and Dry (Actually there is a 3rd now that I think of it but it's not working well this year)
The wet method you fill all your lines with pink stuff (RV Antifreeze) and come spring you got to flush all that yucky stuff out.
The DRY method you blow the lines out (Say that to the tune of Blow the man Down) several times waiting a few minutes between blows, Pink up the drain traps and toilets and come spring,, Well the only lines that are Pinked, you flush in the due course of use, No special flushing needed.
Oh the 3rd method.. SOUTH, I am only 50 miles from the Flordia State Line and yes, it has been freezing on several nights so far, though not enough to bother me inside the Motor home, and the water still flows.
About RV Newbies
