Vic_Bc
Nov 29, 2014Explorer
DutchmenSport wrote:
That white hose? To me, it just doesn't make any sense, UNLESS that round knob (on the bottom of the water heater) is another valve. If it is a valve, then all you need to do is turn it. It will stop anything from going into the water heater, and will travel up the white hose. At the top of the white hose, there should be a check-valve that will prevent anything from back-filling into the water heater.
Water heater: cold comes in the bottom, hot comes out the top.
Now!!! If that round knob is NOT a valve you can turn, (and this is what I think ... you have to take off the white hose from the bottom, and take off the gray hose from the bottom and hook them both up together, which will then manually by-pass your water heater. The connection at the top of the tank should still have a check-valve to keep anything from back-filling into the tank. However this does not make a whole lot of sense either, because that would also allow cold water to go up that white hose, missing the water heater completely, mixing hot with cold giving you luke-warm. (Maybe that was the intent?)
So the real question is, what is that round thing on the bottom pipe joint? is that a valve, if so, simply turn it and your in by-pass mode. If it's not a valve, you've got a very strange set-up.
After further investigation that grey round knob is in fact a valve I am able to turn.
There's also another valve I missed at the top making three valves in total.
So when this valve on the right side has been turned off, that obviously stops the water there, but there is no way for it to get into the hot water lines, correct?
The two valves at each end of the white hose are currently sitting in what looks like bypass mode already?
About RV Newbies
