JimK-NY
Oct 05, 2019Explorer II
Bob/Olallawa wrote:
Clean the contacts at the board and try again. If that doesn't do it, it sounds like a new control board is in order. If warranty is still good take it to the dealer if not order a dinisor board replacment.
No. People make this mistake so frequently the Atwood manual even has a warning about NOT replacing the board. They hardly ever fail.
Some of the older Atwood water heaters had issues with loose connections to the board. I actually had to put a metal binder clip on the harness connector to keep it tight. Eventually I also had the ignitor burn out. That was a $10 replacement. The ignitor did spark but the flame detector portion stopped working.
About RV Newbies
