Taking off on first extended trip. If we use a Pilot (or other big truck stop) gas station for diesel, is there a certain pump area we should use? Should we use the one the semi's are in? We have a...
We use regular service stations with diesel ......cheaper than Flying J/Pilot or other trucking centers, cleaner because not as much fuel is spilled due to the high flow nozzles, less congestion.
Getting in/out is not much different than CG sites.
IF you use a trucking center, use the same lanes as semis.......fuel up then get out of the fueling area
