Gjac's avatar
Gjac
Explorer III
Apr 26, 2018
Kohlar 5CKM21 genset not getting fuel
Genset runs fine when I draw from a gal can of gas but will not run when hooked up to the main tank. I thought the main hose might have a pin hole in it but when I use a hand pump on the line it will fill my clear plastic filter and not leak back into the tank. Bought a new pump 5 to 9 psi, thinking the old pump was weak, but still will not pump fuel to carb. Thinking maybe the fuel pump had the right psi but not the proper flow rate I took a clear plastic tube and put it into a container of gas to try to simulate the position of the main tank and the length of the hose to the height of the carburetor, and both the old pump and new pump pumped a good amount of gas. I am at a loss as to why I am not getting enough gas to keep the genset running. Any help would be appreciated.
