Two Suggestions, both work, one works real good
1: Raise the RV.. of course this may not be practical if you need more than a few inches of lift... *or* (Even better)
2:
Flo-Jet portable Macerator pumpThe Link is to Camping World.. NOT where I got mine
In the photo at the top of the (That's what's that part is for) motor there is a rubber cap.. under the cap is a shaft with a slot.
On this pump if not used often the rotor "Sticks" and you must use a flat tool (IE: Quarter) to turn the shaft in the direction indicated by the outlet connector.. Then it works (Do this when hoking up)
Finally figured out what that rubber cap is for.. Thanks for making me look this up.
(The cap was loose in mine).
This device uises 12 volts to pump up hill.. You can even put the tote in the bed of a pickup truck and pump up to it, if you do this though put something high you can hang the hose on when you are full up.. There is a flush fitting, I run several gallons of fresh water through the pump at the end of the dump cycle to clear the line.. The "line" is a 50 foot black rubber hose.. Yes, Black hose for Black water.. I also have a 25' Gray hose (Wash water tank drain, but that's another story).. No other hoses are black or gray in this RV.
