mlh
Aug 08, 2014Explorer
I resealed my fridge and a skylight recently. You can probably figure on using a tube per vent/skylight/fridge on the roof. Of course, I pulled up the old stuff completely and resealed it from scratch. Touch ups will not use that much. If it hasn't been resealed or touched up in a while, I would recommend pulling up all the old stuff. Don't use it on the AC. The AC has a gasket that goes in between the unit and the roof. You probably should look into replacing that gasket as well.
About RV Newbies
