westend
Aug 12, 2014Explorer
Beaker wrote:The vent cover is probably a poly-acrylic material and, if it's been deteriorating in the sun, it may have a real heavy layer of oxidation on the surface.As mentioned two biggest is getting the surface clean and rolling it out good.
In case you missed it, here it is again.As mentioned two biggest is getting the surface clean and rolling it out good.
I did my roof last week and accidently cracked the cover over the bathroom fan. No problem, eternabond. NOT!!! I was sure that the vent was fiberglass, which eternabond is suppose to stick to. Would not stick at all. Would have been easier to get it to stick to a melting ice cube.
Anyone know what material might have been used for that vent?
FWIW, I patched my Daughter's snow boots with Eternabond. I didn't clean the boots before applying the tape so it eventually lifted along one side.
About RV Newbies
