jasult
Mar 09, 2014Explorer
Ole Man Dan wrote:
I park mine on a concrete pad.
If you use gravel use treated boards in the off season.
It's too easy to throw a piece of carpet on the gravel to crawl under and work...
I put down gravel 5 years ago and put down PT planks under tires and jacks. I saved my bed liner when I installed my fifth wheel and cut the bed liner sides off so I ended up with a flat slippery mat for working under trailer. It is soooooo nice to slide around under trailer on that thing. If I drop a small nuy ,bolt or screw it does not disappear for ever. And I stay dry :W
About RV Newbies
