If you have the electric type heating pads on the bottom of your tanks, you dont want to turn the heating element on unless there is at least enough water/waste water in the tank to completely coat the bottom of each tank. With nothing in the tank to absorb the heat,the heat element will soften the plastic at the bottom of the tank to the point that the bottom will eventually sag in the center and will no longer drain properly.
I found this out from a friends rig that had odor problems no matter how long he flushed his black tank. When we inspected the tanks we found that his tank was sagging about 2 inches in the center therefore would never completely empty. The tank was so soft that you could push it in with your hand with very little resistance. We were scared it may burst any second.
