RVcrazy
Mar 18, 2016Explorer
You will use lots of propane. Be sure you have full tanks. Setting it at 55 and opening cabinets under the sinks, opening bathroom and shower doors will also help. Do you have heated tanks (heat to your storage areas)? Don't use electric heaters if you do because it will make the thermostat not send as much heat to the tanks and they might freeze. Get to a warmer climate ASAP. Good luck!
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
