downtheroad wrote:
Here is a direct link:....LINK CLICK
You are asking a lot from your truck...probably too much.
35+ footer with a GVWR of around 11,000 lbs. Dry hitch of almost 900 lbs.
Hopefully others will be more encouraging, but I think you are in 2500/250 territory.
and...Welcome to the Forum.
X2, way to much trailer for a 1/2 ton even empty and especially if you think pulling an RPod is scary. If your keeping that truck I would suggest you keep the TT GVWR 7,000# or less. If you get a properly equipped 3/4 ton truck then that trailer would be fine.
