Old-Biscuit
Jun 24, 2013Explorer III
Happy.Camper wrote:
thanks for the help ..
What does the ice do ?
the camper is on my land up north, and would be very difficult to haul somewhere where i have a garden hose for water pressure .. I've been boon docking it since I put it there, and hauling 6 gallon jugs so far ..
Therein lies your problem......
Due to lack of available water you are NOT using enough water when flushing toilet, when dumping tank & rinsing/flushing after dumping.
When flushing solids...toilet bowl needs to be filled
When dumping tank.....level needs to be almost full (the volume/weight of liquids carries the solids out)
Water needs to be added back into tank after dumping...so tank bottom stays wet (harder for stuff to sick--dry out and pile up)
You have a poop pyramid right at the toilet dump line into tank.
You will need to break that pile up (heavy spray from water nozzle/wand, stick, awning rod etc. and heavily flush tank.
Good luck......
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
