opnspaces
Jun 24, 2013Navigator III
When you drained the tank, did it sound like it drained? Could it be that your drain valve is not opening and the tank is actually full?
If you think the valve is working and then tank is empty, then yes try a stick to see if you can stir things up and move it along. If you can move or break up the pile then leave it full of water and let things soften for a while before dumping again.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
