thehippie's avatar
thehippie
Hitch concerns
I have a 2015 3500 Ram cummins and i tow about 9000 lb trailer.
I bought a 17k lb rated shank and a 30k lb rated ball but is it too short? will i have problem on tight turns?
  • tomman58 wrote:
    The picture I see isn't like any hitch I've ever seen for towing that much weight. Also as mentioned this hitch isn't adjustable it is important that the trail tows level. I should say very important. I also do not see any torsion bars or anti sway device.
    You really need to go to a qualified TT dealer and have them set this thing up for you.
    I have wd hitch with sway bars which I always use.
    But when I camp just a mile away backroads I just use this other hitch and drive slow.
    It tows level bec I put the shank upside down
  • Tom man..... settle down. Moderate size trailer for the truck that’s pulling it.
    No wdh actually needed to be safe.
    He does have the WDH with torsion bars. Heck the trucks some pull with are way overloaded but that is not the case here.
