Mortimer_Brewst
Jul 14, 2017Explorer II
Grit dog wrote:Mortimer Brewster wrote:
I would avoid using WD-40 (torque issues). Instead keep a long breaker bar on hand. It would be a good idea to re-torque after 50 miles as well.
How many here would replace the "good" tire that's adjacent to the flat as well?
You should expound on what the torque issue might be. Takes less torque to loosen a rusted lug nut if it's WD40'd?
If you mean torque when re installing, there is absolutely no issue. In fact proper bolt tension is more accurate with lubricated threads. It's a requirement in other applications where bolt tension is critical.
Or don't ever have to worry about frozen lugs and anti seize your wheel lugs pre-emptively.
This is from tire rack.com:
Under- or over-tightening wheel-attaching hardware can be damaging and dangerous
Torque specifications are for dry threads only. The fastener threads should be free of oil, dirt, grit, corrosion, etc. The hardware should turn freely without binding when tightened by hand. It is important NOT to lubricate hardware threads or seats. The friction at which torque is measured against should come from the hardware seats. Lubricating hardware threads and seats alters the friction generated at the lug seat which will result in inaccurate torque readings and/or over-torqueing of the hardware
About RV Newbies
