babock
Jul 18, 2017Explorer
Dry threads only. If you live in an area where rust is an issue, you loosen each nut at the beginning of the season a couple turns and retorque. There are specs for dry and lubricated. If you use the same torque spec of a dry thread for a lubricated thread, you may over torque by up to 25%. Sure fire way of having broken studs and your wheel flying off.
About RV Newbies
