IAMICHABOD
Aug 02, 2020Explorer III
If you can find your water tank it may have a drain on one side of it like this,
Turn the valve so lines up with the pipe and it will drain under the RV.
Or if you can follow the line to the water pump sometime there is a valve there that you open and it lets the water out under the RV.
About RV Newbies
