wa8yxm
Aug 02, 2020Explorer III
There are several ways depending on your RV and it may not be necesary
Some ways: First my rig. If I follow the pipe from the tank outlet there is a quarter turn valve. I turn this and no water leaves the tank so now I can change pump safely (YIPPIE)
next is a T-fitting and the T-line runs to the pump. the Through line to another quarter turn valve to an outlet under the RV to drain (Come back tomorrow)
There is a 2nd outlet on the tank (I installed a petcock)
Some rigs if you crawl under there is either a capped pipe or a valve or both
Court of last resort.
Somewhere ABOVE the tank is a gravity fill.. Siphon hose.
But there should be a drain and a cut off valve to the pump.
About RV Newbies
