- wopachopExplorerCan you hear the pump turning on?
- LwiddisExplorer IIYou should have used the low point drain a number of times before this incident. For instance to drain the fresh water system after sanitation.
- ken56ExplorerThere should be a low point valve under the trailer for the tank. Why do you need to empty the tank to replace the pump? Why do you think the pump is not working? Whats it doing?
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
