JoeTampa's avatar
JoeTampa
I'm caught in his jet wash!
Every time I am towing the TT and a bus, semi, or similar large vehicle passes me with a reasonable difference in speed, I get pulled abruptly towards that vehicle from the rear. It doesn't cause any real problems except to my heart rate.. But is this normal?
  • do you have your TT and hitch set up properly. once you get the set up correct all that will be gone. I don't have that problem with my 35 ft or my 25 ft TT's/
  • Inflate your tire to max psi cold and most will go away.....
    Its normal for Less truck and too much camper...
    I was in the same boat
