spadoctor
Oct 13, 2013Explorer II
the cable system has been unreliable since it was introduced in the 1980's and still is. Think about it...if it is built correctly you should not need to carry cable repair kits with you. Manufacturers are using it for lower weight and cost....its that simple. Also unless a design change has been don OR uses 1/2 inch non t&g plywood for the floors. I was not impressed with them when I toured the factory. That being said any company can build a bad rig....your experience is only as good as the dealer.
About RV Newbies
