craig7h
Mar 09, 2017Nomad II
Each to their own but I think its a bad idea all the way around. Forget the parking of the unit, that would be the small part. Each time you would have to clean out the inside of all parisable food etc. Turn off the frig. clean it. Then once you start back again fill everything up. So that brings to mind you will have to rent a car at each spot so you can get around. I think you might want to make other plans. But either way good luck
About RV Newbies
