cj_rezz's avatar
cj_rezz
Leveling a trailer with tandem Torsion Axles
Hi All,
I have a question that I can't find an answer to that I was hoping you all could help me out with.
I just bought a used Jayco 23B trailer. My driveway is sloped at about a 4 degree angle which results in my trailer tongue jack having to be fully extended plus sitting on an additional 17" block.
The only way to fit a 17" block under the tongue is to lower the tongue jack all the way, place a jack stand under the tongue, retract the tongue jack completely and then place the 17" block under. Is this acceptable? Is there an easier way?
This results in the rear axle being fully compressed and the front one drooping completely although still touching the ground.
Is this okay? Can one axle support the majority of the weight long term?
When not using the trailer, is it better for the trailer to be parallel to the slope of the driveway instead of level?
On a similar note, when leveling the trailer side to side at a camp site, can I elevate just one wheel of one side of the trailer or do I have to raise both wheels of one side to level the trailer side to side?
