Old-Biscuit wrote:
ON EDIT:
Just realized you have a Class C?????
To raise backend of rig you will need to have blocks under all 4 rear tires
To raise front end of rig you will need blocks under both front tires
To level side to side you will need to have blocks under front/rear tires on low side
Always post what you have OR fill out 'signature' so info will be at bottom of your post so folks know what you ar asking about
Thanks OB! I filled out the rig info in my profile, but it doesn't show up in the signature part. I will try again.
