Land_Yachters's avatar
May 17, 2020
Leveling Question
Can't find answer to this pretty basic question, but thought I would reach out.
New to RV with 2018 Tiffin 33aa. Only bought it in fall to winterize it and put in storage. I am preparing to get on the road and have MANY questions, but will limit this post to only one.
I have leveled it to move 4 slides out. All good, But when I level it, one rear wheel is pretty close to being off surface. Can't see light under it, but not much weight or any is on it. I have not left it in that position for more than a few hours, but want to leave it that way for a few days while I work on it. The coach is level, but I am concerned about damage. I have been told and read multiple times not to raise tire off surface with leveling.
Appreciate the input.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok on a motor home. if it has "drive shaft parking brake" then having one rear wheel off the ground is not a good thing... One Front is OK
    Do not have both --either end--off the ground,.
    if it has wheel applied parking brakes. You are good.
    Suggestion. Carry a few plank. one (or two if it's duals) 3 or 4 feet long
    two more about half that length and again two more 1' They should be at least the width of the tires
    Mine are 2x12's 3' 2' and 1' long (Tires are 8" so I also have some 2x8 assemblies 3' on top of that is glued a 2' and on top fo that a 1)
    PUll onto the plank to "pre-level" that corner then use the jacks. YOu will stil have good "engagement"
    if you are already parked. Consider a 12 ton (or 20) Air/hydrauilc jack from harbor freight and oh say 6 gaLLON 150 PSI TANK TYPE COMPRESOR.. pICK THE WHEEL UP AND SHOVE THE PLANKS UNDER. DROP DOWN. gOOD.
    hAd one 5er owner having the devil's own time positing on his leeling boards. Finally told him "Get it level and then we will position the boards. I can only pick up 12 ton (You can imagine the look I got) Loaded the compressor and hack in the wagon and pulled it over.. and .. I can only pick up 12 tons.
  • You’re not planning on working under it on levelers are you? Not a good idea if you are.
    If it’s just the one then you should be fine but not a good long term situation. Many people will let the front wheels be off the ground but not the rears.
  • Did you use the "auto level" or manual level? I have found that at times the auto level will raise the coach more than is needed. I have gone back to doing the manual level more often than not for that reason. If you did use auto level you might want to read the manual on how to recalibrate the system.
  • Shouldn't be a big deal for a few days. If it was going to be like that for a week or more I would probably put a couple boards under the tires.
  • accsys wrote:
    Lower both rear wheels a little bit, both at the same time, and you should be fine. You will be a little off front to back but as long as you leave your reefer off there shouldn't be a problem. If you have a residential reefer you don't even have to worry about that.
    No need to leave the refrigerator off under these conditions. Absorption refrigerator specs call for it to be within 3 degrees side to side. On a 30' RV you would have to be off level by more than 18" front to back to be more than 3 degrees. A couple inches will make no difference at all.
  • Lower both rear wheels a little bit, both at the same time, and you should be fine. You will be a little off front to back but as long as you leave your reefer off there shouldn't be a problem. If you have a residential reefer you don't even have to worry about that.
  • That happens, if it is a worry, drive up on a board or two. You should have a selection of boards anyway because you never know what the conditions are when you travel.
  • What does Tiffin say about leveling in your owner’s booklet? Had all Fall to work this out.
