- ksg5000Explorer IIOn my rig the only water pump fuse I ever found was located on the DC distribution panel.
- raross61ExplorerIf it has a 120 volt to 12 volt converter, there are usually fuse's loacted there too. Under the cover, sometimes has a knob on top.
Hope this helps Bob - Old-BiscuitExplorer IIIPump is going to be very close to fresh water tank. In-line fuse will be at pump
Most likely Service Center in outside compartment -----behind the panel
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
