wanderingaimles
Aug 01, 2020Explorer
CMKelin wrote:Back to you tube, input your interest in the search bar, and go as wild as you wish.
I don't have the luxury of years researching everything I need to know to get started.
Since I don't have roots and can work remotely, I want to hit the road ASAP.
I can't seen to find a source that gives a concise and exhaustive how-to guide.
I'm always left with questions.
For instance:
Everything I need to go off-grid? Depends on where you are going, and what you will be doing. Able to work anywhere ? INternet required? If so unlimited data on a cell plan and use as a hotspot, or a stand alone. Otherwise you are tethered to unreliable wifi sources.
Basic equipment everyone should bring such as
emergency repair kits, hatchets, saws, etc. ? Basically what you are comfortable with, space and weight will be limiters, so trim down with that in mind, also get handy with a multi meter if you aren't already. Google "the 12 volt side of life" for help.
The best way to find caravan groups to start out with?
All the places you can safely & legally boondock?
You tube has a lot of material, from How to's to videos of specific campgrounds, the above is an example.
You Tube
Also curious as to what you think the best rig is for a small signature and versatility?
It depends on how far off the beaten track you want to go. For workspace as well as living, I would think a Travel trailer may be better suited, especially considering the ability to have larger tanks and an area to set up as a workspace.
Is there a guide to must-see locales? Maybe a kind of itinerary on how to hit all of them?
About RV Newbies
