DrewE
Oct 01, 2015Explorer III
Tiger02 wrote:
I'm sure there is a way to change it to mph. Even my ancient 97 F350 can be switched with pushing and holding the trip reset or select button. You can even adjust it for different size tires. I'm sure this existed in your model year. I'd hit up the model specific forums as I'm sure this has been dealt with before.
Good luck with your purchase either way.
The Ford E series did not get a digital electronic odometer until 2003. Up until then, it still used the mechanical "slot-machine" style. If the OP's class B is on a Ford chassis, it's definitely not going to be able to change to miles electronically.
About RV Newbies
