RMZ813 wrote:
20.5 inches wide and 11 inches high
That’s almost exactly the external dimensions of the microwave I just installed in my camper. It’s a Panasonic NN-SD372S with inverter technology, and it’s 19 3/16” wide by 11” high.
The nice thing about these inverter microwaves is that when you turn the power level down, they actually lower the wattage of the magnetron tube, instead of pulsing it off and on at full power when you select a lower cooking level.
Exactly what I need when we’re using my little Yamaha 1000 generator. When we’re on shore power, I can let’er rip at full power. When the Yamaha is running I can set it on “5” and it will stay under the 900 watts the generator capable of.
:R Let’s Go Girls! :P (End of quote)
NRA Benefactor Life Member
Lance 1121-Two Awnings, Slide topper, 3.6 kw Gen, Trimetric Batt. Monitor, 1500W Inverter, 40A Redarc DC-DC charger. 2016 F450 6.7 PSD.
